Help Need Help receing text......
vandyman
Android Expert
I can send text, but I can not receive any text.
My Nexus is setup on the T-Mobile pre-paid.
Using Go SMS Pro.
Tried using Hangouts with the same results.
Any ideas?
It's possible they could be fighting over handling messages. Did you change your default messaging app from Hangouts to Go SMS?
Yes, When I switched between the two apps it asks if you want this app to be the default sms app.
I thought that I read about this problem on the Galaxy Nexus before, but has been months ago.
Just wondering if I need to delete a folder are file to reset the data.?.:confused:
Fixed, the porting from Verizon to T Mobile was messed up.
I can receive text and calls now.
PS. Sorry for the spelling in the Main Header.
(receing = receiving) ;)
