Help need help rooting 4.4.4 at&t
dogdog130
i just bought my first android it is unlocked from at&t using it on tmobile well i was told i needed to root to swap everything to tmoible . went to towelroot and said it not supported and tried the other codes anything im missing
I used iroot - it was the only way I could root my old phone after trying many other methods, it claims it can root any android device.
if you search for it you will find videos how to do it.
