flying finn
My TP picks up my dlink dir655 router signal perfectly, but it is an open connection. During setup on Prime, it asks for network ssid and then a security line. Choices are wep, wpa/wpa2 PSK and 802.1x EAP. SSID for dlink is "dlink". I have tried each security setting then adding the password which is the pin # under the router. What am I doing wrong? The pin worked when I used it with my HP laptop. I want it to be a secure connection with the little lock next to my wifi signal.
