JDuc
yes, I'm a bit lost at this point.
I've flashed Flipz 2.1.2. 3rd ROM at this point.
I'm interested in utilizing Apps2SD, but I've got a few (a lot?) of questions. Having some trouble understanding what I'm reading out there and think that the best way for me to grasp it might just be to start my own thread and see if I might be able to find someone kind enough to answer my questions.
1) When running a ROM that has Apps2SD built in, you're not automatically utilizing Apps2SD, are you? I wouldn't imagine so if you've not partitioned your SD card?
2) I'm under the impression that just by viewing my SD card within windows, as it's mounted from my phone, I'm still not seeing everything. Is this the case? I can see the /sdcard folder from windows. However, is there another folder that I'm not seeing? A /system/sd folder? Am I not seeing it because it's part of the core?
3) In order to utilize Apps2SD, I understand I need to wipe my SD card. If I mount my SD card, access it from within Windows, copy everything over in a folder to my Windows machine, wipe the card, then copy it back, will I catch everything necessary?
4) That's all for now but I'm sure I'll have more.
Many, many thanks in advance.
