globalmark
Hi
I am trying to remove the "optus" applications (australian provider) in my phone and read that this Root explorer is the best one to use - so I paid and installed the application - however all the info i can find says go to -
Systems _ App then select the unwanted applications and delete or uninstall !
However none of the Applications I do not want are in that file , they are all in
System_ Carrier _ persist-app and if I try the same way of deleting/uninstalling it does not let me
if i click on the unwanted Application it give me a Choice or install, Cancel or View (install just installs not Uninstalls)
How can I get rid of these unwanted applications - they are Optus Directory Assist, Optus Music store, Optus Applications Store, Optus MY Account, Twitter and Ciao all stuff i will never use or want .
Thanks Mark
Thanks Mark
