need help with a profile timer w/ countdown
dcooterfrog
ARGH purpose of the profile
start when a programs in a list are started.
count down the time with flashed every x minutes
warn at completion
do something disruptive
alert or alarm or close the app or lock the screen or just bounce to home
I am having trouble with flow control with the subroutines.
the closestop subroutine starts before the countdown is complete.
i had a simpler countdown that woud simply wait and then go to the top. if not enough time had passed. i thought the problem might be the wait so I wrote it like this.
actually its just some parts of the close that dont wait for completion.
the home key or a pop up or a notify.
flash seems to wait but its not disruptive enough
z+rZkV+YgicMgAAAABJRU5ErkJggg==
Main (3)
A1: Perform Task [ Name:Init Stop:Off Priority:8 Parameter 1 (%par1): Parameter 2 (%par2): Return Value Variable: ]
A2: Flash [ Text:Timer Starting
%TimeAllowed Minutes Left Long:Off ]
<CountdownTask>
A3: Perform Task [ Name:CountDown Stop:Off Priority:9 Parameter 1 (%par1): Parameter 2 (%par2): Return Value Variable:%finished ]
<wait for completion>
A4: Wait Until [ MS:0 Seconds:1 Minutes:0 Hours:0 Days:0 ] If [ %finished = 1 ]
A5: Flash [ Text:Time is up!
%finished Long:Off ]
<CloseTask>
A6: Perform Task [ Name:Close Stop:Off Priority:8 Parameter 1 (%par1): Parameter 2 (%par2): Return Value Variable: ]
A7: Flash [ Text:Back to main Long:Off ]
Init (4)
A1: Variable Set [ Name:%TimeAllowed To:10 Do Maths:Off Append:Off ]
A2: Variable Set [ Name:%TimeRemaining To:%TimeAllowed Do Maths:Off Append:Off ]
CountDown (5)
A1: Variable Subtract [ Name:%TimeRemaining Value:2 ]
A2: Variable Set [ Name:%waitstart To:%TIMES Do Maths:Off Append:Off ]
A3: Variable Set [ Name:%waitend To:%waitstart +10 Do Maths:On Append:Off ]
<Donewaiting>
A4: Anchor
A5: Flash [ Text:%TimeRemaining
%waitstart
%TIMES
%waitend Long:Off ]
A6: Variable Subtract [ Name:%TimeRemaining Value:1 ]
A7: Variable Add [ Name:%waitstart Value:1 Wrap Around:0 ]
A8: Goto [ Type:Action Label Number:1 Label:Donewaiting ] If [ %waitend > %waitstart ]
<finished = 1>
A9: Return [ Value:1 Stop:On ]
Close (6)
A1: Flash [ Text:Closeing now Long:Off ]
A2: Go Home [ Page:0 ]
wGmv9zluz+bkQAAAABJRU5ErkJggg==
