Need help with app
Dell14z
I am trying to put a banking app on my Coby Kyros. The bank is Citizens Bank. I found it on the iTunes Android App Store. But, there is a problem as the download link isn't working. I clicked it but "download unsuccessful." I went back but the download link had changed to (I forget) something else.
Is there an App Store --it is listed like that on the bank brochure -- that you would recommend for the Citizens Bank app found on iTunes?
Thank you
Thank you! I didn't check Amazon if I remember right. I just know iTunes was a problem. Later tonight I will go to GetJar on my Kyros and let y''all know how it went.
Have you installed Amazon Market? It should work. You can also use GetJar. You can't use iTunes at all (I wasn't asking a question earlier, I was wondering why you were trying :) )
But, Citizen's isn't on Amazon anyway.
Ah, thank you. Didn't realize I had to install an Amazon app. Tonight I'll be busy :)
iTunes had the app but now I know why it didn't download.
Amazon Market. -- this app has been removed from the market
I did a Google search, found an Android-named site and got the above message.
I also saw both the Market and an app.
Do you have a URL?
