I am having trouble getting this set up correctly.
I followed the instructions formatting the sd card and it seemed like the ext2 partition set up correctly, but after running appd2sd the phone just hangs on the flashing android. Does it take forever to reboot after running this? I only had maybe 10 apps on the phone to move to the sd card. I wound up wiping the phone after 30 minutes of waiting.
If I look at the drive in partition manager, the ext2 partition no longer shows up. It appears to only see the fat 32 partition.
I'm at a loss as what to do here? I tried deleting the fat32 partition, but nothing I do seems to let me see the other area of the card to verify the ext2 part.
I am running jf-1.5, and using paragon partition manager 9 in Vista.
