I have just switched over from a blackberry 8330 that I have had for years to the LG Optimus, I use geocahing to fish with, I sometimes fish in other boats that do not have gps capabilities and I use my smart phone instead. I have hundreds of locations saved on gpx files.( I also put them on the sd card) I downloaded the c:geo app and it successfully installed. When I open the app and select stored then select menu and select import gx files it finds and shows them on the card and I select them to import it says 0 files caches imported. Is there another way to install these files? I'm about to go into panic mode.
. LOL
. LOL
