okay i flashed cm7.2 on my phone the other day and found that the 3g doesnt always work the camera doesnt work for pics and mms doesnt work..does anyone have a solution for this..?(and btw the rom is awesome i recomend!)
If 3G isn't working, then MMS isn't going to work. And the camera issue isn't a simple 'fix'. It involves actual code, which I'm working on. If 3G isn't working, try the following adb command (not gonna teach you how to use adb, have more important things to do):
