I gave my son my old gnex and he wanted to play pokemon go on it so I rooted it and flashed cm. I thought I was downloading the 4.4.4 version but it turned out to be the 5.xx version. Not a big deal but I downloaded and installed the gapps for the 4.4.4. So some google apps aren't working right. Do I need to uninstall all of the google apps first or can I just install the correct gapps over the ones that are on there? I already downloaded the ones for 5.xx
thanks
thanks
