Help Need help with identifying a display symbol
burgur99
I just purchased a Samsung Galaxy tab 2 10.1 about a month ago. Just the other day a symbol appeared in the right hand corner of my screen right next to the time display. I have tried everything I could think to find out what it means and how to get rid of it but havent had any luck searching on Google or on any forums. Here is a screen shot of my tablet's display. As you can see from the pic the symbol is of a circle with what looks like a lowercase "i" inside of it with a slash mark throngh the circle. Can anyone identify this symbol, what it means, and how I can get rid of it?
Your notification is disabled in settings - tap the clock, bottom right and scroll through settings (wifi, gps, sound...) should be green.
I have the same issue in my galaxy tab 2 7''... PLease help.....
1) Tap bottom right hand Corner small screen will open
2) look at the top there is a list of green icons wi-fi /bluetooth/ GPS
3 Scroll left or right you will see one marked "Notifications " Tap it to turn ON
Green is On Gray with cross through is Off
Thank you Brian566 my tab had same problem. Just discovered the scroll aspect on small screen so thanks again
Red58
Thank You. I had no idea it scrolled.. hehe :)
