ac4android
I am trying to create a login app using email and a password using HttpURL.
I am getting an email/password error back from the PHP I've created on the remote server.
Here is the XML that gets the email/password variables, the work well:
Here is the part of the Android Java that grabs the email/login and send the pair to PHP:
And here is the PHP, it works, I tested it on Firefox,= & Chrome, it gives me the data if it gets the right email/password, else it tells me "Wrong email/password!". But it always return the result "Wrong email/password!" to my app.
PS 7/10/2017:
I forgot to add: JSON_STRING is null since PHP returns nothing. Worked myself into a rut again...
Code:
<EditText
android:id="@+id/et_email"
android:layout_height="wrap_content"
android:hint="@string/prompt_email"
android:inputType="textEmailAddress"
android:maxLines="1"
android:singleLine="true" />
<EditText
android:id="@+id/et_password"
android:layout_below="@+id/email"
android:layout_marginTop= "25dp"
android:hint="@string/prompt_password"
android:inputType="textPassword"
Code:
$email = $_GET['email'];
$password = $_GET['password'];
$sql = "SELECT b.User_ID, b.User_Name, x.Unit_ID FROM Users b
JOIN X_Users x ON TRIM(b.Email) = TRIM('$email') AND TRIM(b.Password) = TRIM('$password')";
$result = mysqli_query($conn, $sql);
if (mysqli_num_rows($result) > 0) {
$response = array();
while($row=mysqli_fetch_array($result)){
array_push($response, array("User_ID"=>$row[0], "User_Name"=>$row[1], "Farm_ID"=>$row[2]));
echo json_encode(array("db_response"=>$response));
echo'{"query_result":"Welcome back."}';
} else {
echo'{"query_result":"Wrong email/password!"}';
PS 7/10/2017:
