Need help with manual app update
nohsp4u
Hello all,
I have many an App installed on my Thinderbolt. When installing them i had selected to auto update to save me from doing it. The issue i have is the TB is shutting off and rebooting alot.
I am looking for a quick and easy way to reset all app to manual update. I think this may be the cause of my issues. Something like windows BSOD, when two programs fight for the same piece of pie it goes to BSOD. i think the android system might have the issue is two or more apps try to share the piece of pie and then it shuts off or reboots.
Purely a guess but worth a try, please help. TIA
Im not sure if there is a way to "uncheck all" but just go into market/menu/my apps, and go through one by one, it shouldn't take you that long.
