Need help with mobclix!
lot577
Hi!
I was trying to integrate mobclix into my android application which is sdk 2.2. However, the program always crashes when it runs. I tried to make the simplest program possible to test if mobclix ads are working.
public class TestAdsActivity extends Activity {
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
In the manifest
<meta-data android:name="id# (I put it in here)"
android:value="id# (I put it in here)"/>
<activity
android:name="com.mobclix.android.sdk.MobclixBrowserActivity"
android:theme="@android:style/Theme.Translucent.NoTitleBar"
<uses-permission android:name="android.permission.INTERNET" />
<uses-permission android:name="android.permission.READ_PHONE_STATE" />
<uses-permission
android:name="android.permission.ACCESS_NETWORK_STATE" />
and the main.xml:
<com.mobclix.android.sdk.MobclixMMABannerXLAdView
android:id="@+id/banner_adview"
android:layout_width="320dip"
android:layout_height="50dip"
android:layout_gravity="center" />
This is the logcat output.
12-21 15:03:02.241: I/Process(1520): Sending signal. PID: 1520 SIG: 9
12-21 15:03:05.681: W/dalvikvm(1546): threadid=7: thread exiting with uncaught exception (group=0x4001d800)
12-21 15:03:05.761: E/AndroidRuntime(1546): FATAL EXCEPTION: AsyncTask #1
12-21 15:03:05.761: E/AndroidRuntime(1546): java.lang.RuntimeException: An error occured while executing doInBackground()
12-21 15:03:05.761: E/AndroidRuntime(1546): at android.os.AsyncTask$3.done(AsyncTask.java:200)
12-21 15:03:05.761: E/AndroidRuntime(1546): at java.util.concurrent.FutureTask$Sync.innerSetException(FutureTask.java:273)
12-21 15:03:05.761: E/AndroidRuntime(1546): at java.util.concurrent.FutureTask.setException(FutureTask.java:124)
12-21 15:03:05.761: E/AndroidRuntime(1546): at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:307)
12-21 15:03:05.761: E/AndroidRuntime(1546): at java.util.concurrent.FutureTask.run(FutureTask.java:137)
12-21 15:03:05.761: E/AndroidRuntime(1546): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1068)
12-21 15:03:05.761: E/AndroidRuntime(1546): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:561)
12-21 15:03:05.761: E/AndroidRuntime(1546): at java.lang.Thread.run(Thread.java:1096)
12-21 15:03:05.761: E/AndroidRuntime(1546): Caused by: android.content.res.Resources$NotFoundException: com.mobclix.APPLICATION_ID not found in the Android Manifest xml.
12-21 15:03:05.761: E/AndroidRuntime(1546): at com.mobclix.android.sdk.Mobclix.initialize(Mobclix.java:571)
12-21 15:03:05.761: E/AndroidRuntime(1546): at com.mobclix.android.sdk.FetchRemoteConfig.doInBackground(MobclixConfig.java:52)
12-21 15:03:05.761: E/AndroidRuntime(1546): at com.mobclix.android.sdk.FetchRemoteConfig.doInBackground(MobclixConfig.java:1)
12-21 15:03:05.761: E/AndroidRuntime(1546): at android.os.AsyncTask$2.call(AsyncTask.java:185)
12-21 15:03:05.761: E/AndroidRuntime(1546): at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:305)
Thanks in advance to anyone who tries to help!!
Make sure that the permissions come before the application tag, and the rest are inside the application tag:
<uses-permission
android:name="android.permission.ACCESS_NETWORK_ST ATE" />
<application ----->
<activity
android:name="com.mobclix.android.sdk.MobclixBrows erActivity"
</application
