Need help with multiple alarms
mommyin
Is there a way to set more than 1 reoccurring alarm I can't seem to figure out how to do this.
Thank you for your help
I believe you just press the "create alarm" bar on the top of your alarm screen to make a new one. Just be sure to press save afterwards. Hope that's what you were talking about.
I think maybe I'm using the wrong alarm I'm using the 1 from the widgets and it doesn't seem to have the option you're talking about. Am I in the wrong screen, if so how do I get to where you're talking about? Thank you for your help I kind of feel silly about this.
Open your app drawer and look for the "Clock" app and open it. Choose "Alarm" on the top (there are options for timer, stopwatch, etc.) and that'll take you to what I'm talking about.
I came from an HTC phone where you could get to the alarms by just pressing on the home screen clock. I downloaded the Sense Clock app and set a shortcut to do the same... just in case you wanted a quicker way to get to the alarms.
Various tips to help you along with this:
You can scroll down on the alarm widget, then it should say "Tap to add alarm" I just figured this out cos I was having the same problem hahaha!
The more I use my Android Kit Kat 4.4.4 Note 3 operating system, the more clunky it seems.
On my Note 3, in order to add multiple alarms on the same day, you must first scroll down to the bottom of the alarm page, and re-name the alarm (default name is "alarm"). Once you provide a new name (such as "Alarm2"), and after you set the time and day, when you hit SAVE, a new alarm can be created on the same day as another alarm.
Non-intuitive!
