Help Need Help with my HTC Legend
Hello forum members, I own a HTC Legend and purchase a app called "Beautiful Widget" and unfortunately I didn't like it cause i've notice performance decrease even since i got it and decided to Unistall. So I did, but the icon is still on my phone and when I check with task manager the app is still running and it taking up memory. what should I do from here?
Welcome to the forum CrazyPotato and congrats on your first post. I'm not familiar with your particular device but by the sounds of it... your application is still installed.
My guess is that instead of removing the app, you just turned it off. I would suggest going into your apps.. should be manage apps or something similar and long press on it and remove it.. or hi-lite it and do a menu delete. It will ask you if you are certain you want to remove the app... that will be your clue you are actually deleting it.
Best of luck to you.
