need help with my htc m7
So I had another rom I had tried before and renamed for easy typing in the command line. Tried to sideload that.
Code:
Target: htc/m7_google/m7:5.1/LMY470.H18/666675:
Could not detect filesystem for /dev/block/plat
Mount:failed to mount /dev/block/platform/msm_
Unmount of /system failed; no such volume
Patching system image unconditionally...
Verifying the updated system image...
System partition has unexpected contents after
E:Error executing updater binary in zip 'data/
Looks like its cut off at the end but I cant seem to get it to come up any other way.
What rom are you flashing? Did you try a newer recovery version? 2.6 is very old.... Is Linux the only OS you have or are you dual booting?
I forget exactly what the rom is. I have it relabeled crdroid. I was many links deep when I found it.
I havent tried a newer recovery. I was making sure you didnt need any kind of output first. Ill try a newer TWRP.
Yes, Linux is my only OS. I could maybe get a friend to bring a laptop over but Id only have a few hours with it.
Linux is OK, but in your situation it would be way easier to bring your device back to functional using Windows. I do have experience with Windows, Linux and MAC but most things are Windows based as far as a simple repair.
Your current recovery would probably not flash a rom with a newer OS version as that version of TWRP was used for 4.4.2 and lower if i remember correctly.
Got it working!! Thanks a lot! I just had to update TWRP, adb push cm and gapps over and flash them. All seems to be in order so far!
Thanks again to both of you. I learned a lot.
