need help with my new android
hello i just traded my iphone 3g for a android phone, im not sure what kind it is all i can give you is the model number its "A2000-GPS" its a quadband im guessing u can use 2 sim cards in it. but the thing is when i put my sim card in it, it says no service. the sim card im using is a go phone at&t sim card i used it in my iphone i also have a 3g at&t sim card but it also says the same thing. so i need help getting it to work. im new to this android stuff so dont really know anything about it, ive always used iphones. thanks for any help.
Welcome to the Android Forums!
Your phone is a Star A2000 and is made in China.
Moving your thread to the Other Phones forum as there is not currently a specific forum for this device...
Hi CopenGrizz01,
Can you elaborate more on what was the problem and what you did to fix it.
I am thinking of buying A2000 and use it with GoPhone network also.
-Martin
hello i just traded my iphone 3g for a android phone.
Sounds like a bad deal to trade a Iphone 3G for a chinese Android phone... I am pretty sure your Iphone 3G is going to work better than your new Android phone.
Your Star A2000 is running Media Tek MTK6516 460MHz ARM9 cpu
which is slower than the
Iphone 3G which is using a Samsung ARM 11 processor running at 412 MHz
