I can't get my NTFS micro SD cards to mount in my new Galaxy 8.4 Pro KitKat.
I have root and have given the programs admin privilege neither one will mount my cards, FAT32 works ok but my videos are huge way larger than the 4GB limitation of FAT.
in Paragon auto mount doesn't work, it shows it as unmounted.
I can try to mount manually in a new folder and my Droid sees the folder but not the card and it says unmounted in Paragon.
In Ntfs mounter it says that the sd card would be mounted in /mnt/sdcard/external_sd
but when I try to browse there from root there is no /external_sd directory.
Is there a different app I should be using? I am trying to get this mounted so I can use TrueCrypt containers via EDS Pro.
Please someone help me get this to work.
Thank you.
Thank you.
