Help Need Help with PRLs
CooLoser
I have a few question about PRLs, answer what you can or all if you are able if you want
1) Can my ns4g flashed to boost run on a Verizon PRL?
2) Im on a sprint PRL should i switch to a boost PRL to get my data to work?
3) Do different PRls affect my data speed and reception bars?
Thanks
1) Generally Boost runs solely on sprint prl's. Boost does not roam so it will not work on verizon.
2) From what i gather either will work but sprint prl's should be better because boost prl's only allow you to use certain towers while sprints allows you to use more. ( I think, don't quote me for sure)
3) Yes they do. some older prl's can give you better signal and faster speeds while some of the newer ones can acually make everything slow down and lose signal.
