need help with programming
This really depends on your current level of programming expertise. I would go over to XDA and ask around there. This forum really isn't terribly developer geared and is more consumer geared.
Android development is Java based which is object oriented. I don't know if any of that made sense to you or not. If it did, then a good book or two might get you in the right direction. If it didn't, you should consider some basic programming classes first.
