Need help with Ringtones
UrbanDoom
I downloaded some ringtones from myxer.com and there on the phone. I can go to settings and set them as a ringtone however when i go to them in file manager or astro the file manager that i use from the market place they are no where to be found on my memory card. Does anyone know where they might be stored on the phone.
Yea normaly it should be there but for some reason its no where to be found on the sd card. Is there a way it could have been saved on the phone
Yea i cant find them in files anywhere I have went to every folder on my sd card. I can set them as a ringtone if i go to settings and sound profiles and edit my ringtone that way but no where in file manager
use astro file manager from the market and do a search for the name of one of the ringtones, make sure in search options you allow it to search all files not just sd card. see if you can find them that way.
I didnt know that you could search like that. It didnt find them tho i dont know if it makes a difference or not but i do have it rooted to 1.6
