Root Need Help with rooted LG Volt
Ok I have an LG Volt thats running Android Kitkat 4.4.2. it has like 4gb of internakl memory and I have a 32gb SD Card in it thats not being utilized. I rooted it because I read with a rooted phone you can move apps to SD Card and clear out bloatware, and I need to make space on my internal memory. I have 1gig of free space left and a game on my phone (that i actually want) is taking up another gig. I want to move that to my SD card but it only moves the app (which is only taking 3mb) it wont move the app data which is taking 1gig. How do I move that data to my Sd card?
Ive tried titanium backup but that doesnt list a move to Sd Card option. Ive tried link2sd, but link 2 SD card is greyd out and it says second partition not found (do i really need to make multiple partition on an SD card to do that? Why not just use the free space thats on its default partition?) and when I try to move it from my phone to my SD card in that program I get a failure message that says "App2SD is not supported by your device. Because your device has a primary external storage which is emulated from the internal storage. You can link the app in order to move its files to your sd card" and then sometime if I try to link it says something about os emulation.
So what I need is step by step instruction on how to move an app (including its data) from my internal storage to my Sd card on my rooted 4.4.2 lg volt. OR how to upgrade my lg volt from kitkat 4.4.2 to Marshmallow 6.0 without bricking it because I hear Marshmallow allows you to turn your Sd card into internal storage which would give me 32 GB of internal storage instead of 8 thus I can keep all my app in my new "internal storage" and not care. Thank you.
surely someone must know >.> I thought rooting made it possible to do just about anything you want to your phone aside from make it cook and clean for you. This should be an easy problem to solve if so >.>
Yeah, I'd completely recommend heading over to the LG Volt section and actually looking around for a ROM you might wanna flash. We are working on CM13 at the moment, though it is still a work in progress so looking around for a different one would be recommended. LG stock ROM is absolutely horrible.
