gentrythomas1
im pretty good with working with rooted androids so i dont knowm what went wrong but when i was trying to set the tablet back to stock unroot something happen. i looked at the thread to un root and did everything it told me i loaded up stock bootloader with cwm then flashed unrooted rom with the name update. every time i try to turn it on it gets to the andoriod screen for about 18 seconds then it flashes every 9 seconds without loading up. the tablet is a gen 2 a100 if it makes a difference. if you need any more info i will try to tell you what i can considering it doesnt fully load up.:bawlingP.S. i can still get into stock bootloader.)
