How do you turn the Nexus 4 GPS "on and off and on again" please?
Are you using an application like Google Maps navigation, Trimble Outdoors or some manual technique?
Have you tried GPS Status from the store? That usually kick starts it! GPS on my N4 is spot on, keen even get a really good signal/fix inside. Something my DHD never did.
I searched the store for 'gps status' & got multiple hits for that name. Can you clarify the full title of the one you are recommending or the name of the dev?
Thanks
I have to say that it works if its connected to wifi... Wierd!!!
