Root Need help with ViewSonic G Tab Rooting
I am not very computer savvy when it comes to tablets, and need some help. Is there anyone in the Orlando, Florida area that can help me with the rooting of my ViewSonic G tablet and possible addition of Android 3.0 Honeycomb? Help would be greatly appreciated!
Hi Vinnyss517
Welcome to the forums!! Looks like your original thread was already moved to the Gtablet rooting subforum. You'll find a lot of info here and also some very knowledgable people.
Anyways, you'll want to start by checking what stock ROM you are currently running.
Go to settings and about tablet to see what firmware you are running. You should see something like...TapnTap 3588 or 4349. This is really important because this tells you which bootloader you are on and from there we can guide you to which HC ROM you can load.
Also, all the HC ROMS are pre-rooted as is all the other custom roms for the gtablet. After you done that, here are a couple of reference threads with instructions you can follow. If you are still confused, go ahead and ask a question on that thread or search for your answer there.
http://androidforums.com/gtablet-al...-install-custom-rom-fix-market-add-flash.html
Hi Vinnyss517
Your answer was so much better than mine.:)
Thanks for the help guys. It's just really scary because I just got my first ever tablet and I want to do all of these things to it but I don't want to fry it or anything, but all of these things like ROM's and stuff confuses me and I don't know if I'm just stupid or if it really is not as difficult as I am making it out to be. I am tentative to do anything to the tablet because I don't want anything to happen to it.
And if the honeycom ROMs are prerooted, do I only need to download them and I will have access to the android market and everything?
Lol. Quantity doesn't equate to quality. You're response was also helpful. :)
Don't worry you weren't the only member that passed by here that had the same fears as you.
And it says I am running Taptap 3588
Ok, you are on Bootloader 1.1. As far as I know, GtabComb 3.2 is the only HC ROM that can be loaded using that bootloader. A lot of our members have that HC ROM running.
Most of the custom ROMS and all the HC ROMS have the market and all the google apps preloaded. Root is not needed when all you want to do is install a custom rom.
