Root Need help with Virgin Mobile 5.1 Update XT1526
Sands207
Hi All, I'm using the US Moto E Virgin Mobile variant and I would like to update my moto, every stock update rom i have flashed has worked for the most part... But I have no data, calls and texts. I also noticed that I cannot use or even see the virgin mobile app that allows me to activate and look at my device info after even a dirty flash update and the boost rom locks my sim right up. I can unroot and go that route but but i would like to keep root and start fresh but also have service. Can someone else with a virgin mobile moto e let me know which rom worked for them? I appreciate and hope i can contribute to this community with development too. I am new here after helping in development of the LG Volt. Thanks in advance for any help :)
Sounds like you need the actual system image or a nandroid from a stock VM user...I'd definitely try to find the system.img though to make sure you have the right modem.
Thats exactly what i need and right now im stuck until i can find it.
