Help Need Help With Widget Thing
carney2
Again, new at this, so have patience. I downloaded a battery status widget yesterday, but it is neither in my apps section nor anywhere else that I can find on the phone. Any suggestions?
It is a widget which works out on a home screen kinda like your clock. You need to long press on the home screen where you have at least room for 2 icons wide and a menu will pop up. From there you will need to select widget then then Android widget. In the list that comes up you will find your new widget.
Hope that helps
