Root Need help
Hi, everyone good day to you All, I need some help with support because i have forgotten My password and try to do the hard reset but it still asking me for the password again? Is there any way to get it done because as i have been trying to get it done but it can't? Please please advise me on how to get it done thanks. I really appreciate the help with support.. thanks.
"try to do a hard reset" ???????were you able to get to recovery and select factory reset? and are you talking about the password on the unlock screen? or are you talking about the email and password that you used to setup the phone?
Both password Sir as i have forgotten it and after doing the hard reset it still asking for the password again?
I have tried many times and it still asking for the password again? Please help me out with it Sir, it would be great for me and i really appreciate the help with it thank you so much for the help and support..
But i have tried to login to Google Gmail it can't get through the Gmail account? Error msg showing up? What can be done?
Well if it is a password on the lockscreen, a hard reset should have erased it. If you are talking about the Google account, the only thing you can do is a forget password. If that does not work then you are screwed.
Here is the issue....... by doing a hard reset instead of a factory reset, you tripped Google's FRP(factory reset protection) which is designed as a theft deterrent. If you did a factory reset from within the phone's settings, you would not have tripped FRP.
As you are discovering FRP is designed pretty well. If a thief stole your phone and did a hard reset like in the past, FRP would have still protected the phone from being used.
Soooooooo.......... there really is not much you can do other than a forget password if it is FRP that is in the way.
Don't try to log in to your Google account on that device. Log in to Google with what you are using now or another pc etc. Get a prompt for a new password.
Look in Device Manager on your Google account, if you had used this device before, and see if it is listed.
However, I don't think changing your Google password will help unlock your Pixel 3 at this stage. That is something I'm not knowledgeable on.
Normally it takes 24 to 48 hours for a password change to become active, although I may be confusing this with something else and talking through my hat.
Here's the crux (sorry if English is not your first language) :
Can you tell how you have this phone now?
That is, have you used it in the past and forgot about it - but now want to activate it for yourself again or for someone else.
Did you recently buy it online or elsewhere and now doubt the seller?
Did you find this device?
It will help to know - although as mentioned at this stage you are probably out of luck.
I am curious if you can log in to the Google account you had on the Pixel on a different device.
.. Thanks but i still can't get it done because of the Google account password and i can't bypassed it till now..
Thanks for your information bro but im really looking for a way to flash it.
Yes, exactly. Fingerprint setup to the rescue.
