hey guys my msm doesnt work i have cm7 on my ascend but when i try to send or recieve pictures it keeps loading and loading and never stops =/ i really need help plz help me as fast as u can thanks in advance
A little more info would help... Are you on Cricket or MetroPCS? Did you recently flash cm7, or have you had it for a while and MMS just recently stopped working. If that is the case, have you made any changes recently that may have affected MMS? etc...
If you're on Metro, you may need to flash MetrOFF.
It could be a bad flash... Wipe, and reflash.
It could be a carrier issue...
It could be a lot of things...
also if you are using tibu to restore things, then don't restore anything that had to do with sms or mms...I did and was unable to to receive pics until I reflashed and didn't restore any sms or mms related things...then everything worked perfectly....
