Help Need help.
I was rooted and did with admired monster and did a factory reset and phone was stuck in a boot loop I did a recovery via cwm and got it to boot but I can't get past the setup Google account. After I put my Gmail info in it says set up wizard force closed. My status bar shows up but screen is black and I can't see anything. I tried the stock recoveries and none will work via cwm. Also tried rooted recoveries and nothing. Says md5 don't match. I can't use the 1 click root because I can't see the menu options to set the phone to usb debugging on. Please help.
If you're doing a lot of testing download the official Samsung update to 2.3.6 for admire, It has 100% working update (except MMS & Market needs a tweak for them to work)
:::>> You could download it from here (just install the program connect the phone in odin mode and run)
you could find more info here
this is the fastest way to get your phone useable.
If you want to return to original stock see this topic
http://androidforums.com/samsung-admire/528130-cant-mount-cache.html
Thanks will try as soon as I get home
Hey I tried the the stock recovery that was in the link now it's stuck on the second screen after the first screen that say www.samsung also when in recovery it won't run any recoveries say something about cache can't load. It won't even let me do factory data wipe in cwm. What can I do?
