need help!
lovechloe
hi there!
need help..i got anycall samsung galaxy s..i bought it from a friend and it's not his either..got a problem on my phone..it was locked out..i was asked for my account but didnt worked out, still asking for my google account..i thought maybe they're not asking for "my" account details, maybe they're asking for the former owner's account details..:(
Welcome to AF, well you need to login using your Google account info. have you activated the phone under your name yet ??
hi there!
Hello and welcome aboard. You will need to "reset" the device.
1. Turn the power off.
2. Hold the Volume Down button.
3. Press and release the Power button.
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Select Clear Storage by pressing the Volume Down button.
6. Press and release the Power button.
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO If you selected YES, all data including third-party applications will be deleted from the Samsung Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
I hope the above helps.
Welcome to AF, lovechloe! Good luck with your phone troubles, looks like you have been well taken care of already. Thanks for joining up! :)
