The best advice I can give is to ask in the Galaxy S2 forum. That's where you will find people who know the device and the software and will be most likely to be able to find a solution. Do give as much information about your phone as you can, e.g. current software version, whether it is network branded.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
