mysterious1
Ok dameon 1.42 created by mattlgroff
In this situation i would
Make sure. 211 was on my sd card
Use utility 1.7 to “unstick .211“
Flash 211 in moto recovery
What message is it saying when you try to connect?
... just got home from work so can help a bit more than before now.
No.
Trying to bring phone back to stock .181.
Then ota update to stay on ota path.
It was the safestrap .211. That one can go back to .181 from where he was at.![]()
Depending on how you got to 211 you most likely are stuck on 211.
Can you expand on that because its never been an issue before using the utility.
But i will try later, away from pc now.
Have a happy 4th.
