Help Need help!!
miss_vickies
Hi guys....
Im reaching my data limit... and I got whole 6 gigs to play with. I dont understand how im at my limit since I didnt really download anything... I attached a pic of what says used over 2gigs... can u guys suggest how I manage this better?? And what is that scloud thing thats using so much data....
Thanks so much
Sent from my SGH-I317M using Tapatalk 2
Hi guys....
Thanks so much
Can you tell us what apps you use most often and if you have any data being sync'd automatically (even if on a schedule)?
I thought SCloud was Samsung's own cloud service. I don't have it enabled for auto sync. But then again, I've always had issues with it constantly giving the "sync is currently experiencing problems... blah, blah, blah". Never really bothered with it.
Could very well be. I don't have my Samsung account backing anything up either. I use alternative backup methods.
I dont use anything crazy.... instagram... twitter... chrome....
How do I check whats been eating most of my data in the last month? Or whats backing up... I downloaded some games like need for speed.... I dont know what else has changed
I have never came remotely close to reaching my limit..which is why im a little confused....
It says since march 4 -29 that scloud.datasync:10149 used 3.36gigs out of 6 I have available.... what the heck is this thing n how do I stop it ?? :(((
Yeah I also think that scloud is the Samsung Account sync to cloud. Go under Settings -> Accounts -> Samsung account
Click the email address of your account. You should see 4 boxes: Calendar, Contacts, Internet, and S-Note.
I don't think Calendar and Contacts will eat that much data. I don't know what is Internet, but I am guessing it is browser bookmarks and such. The only thing I could think of that could eat that much data is S-Note. Do you take a lot of pictures, paste them in S-Note and save them? If so, you will want to uncheck S-Note.
I use My Data Manager to track my data usage. It can track data usage by hour as well. It is not 100% accurate, but very close from my experience. Definitely an excellent app to keep track of your data usage. Set notifications, daily data limits, predict data usage, etc.
You might also want to go data usage settings and check restrict background data to Wi-Fi.
Do you have auto-sync enabled? SCloud sync is Samsung's cloud service. Not sure if it incorporates dropbox as well. Makes a difference if you don't restrict data usage and have pics/vids uploaded with the service.
