I assume you are referring to pairing your Bluetooth to the truck? The best place to look for specific instructions would be in your truck's manual.
But you will want to turn on your Bluetooth in the phone settings and you will have to select your truck from the list of devices to pair with in the Bluetooth settings. Before it shows up on the list, it's possible that you will have to do something in the truck first to make it searchable.
The truck manual will be the best place to get all of this information as it will be specific to your truck. They should provide you with the passcode for the Bluetooth which is generally something generic like 1234 or 0000.
