Need Help!
I NEED HELP!!:mad: I have Karbonn A21 rooted with Framaroot, not sure what heppend to this but it stopped working since this morning. I also have font installer on my phone and i tried to change the font and since the it is only showing the boot animation doing nothing else. Please all you talented peoples help me out.
Hello and welcome aboard.
Thanks for stopping to join our community. Hopefully we'll be able to assist you with your concerns today.
It would be best to check inside your device's root forum for help on this matter.
Good luck. :)
Do you have a working backup made via your custom recovery? If so, I would enter recovery, wipe everything (except sd card if your device has one), and restore your backup.
It's always good to make a backup before changing any system files, this being the perfect example.
If you don't have a backup made, you will probably need to reflash your rom.
I'm not familiar with that process for your device or where to find the appropriate files..
But you probably need the stock rom/firmware that you can flash via recovery. I can't seem to find it anywhere.
