Ummm...Dear Wizard,
Can you please make or port any of LG devices kitkat rom which is similar to LG Volt.
I don't get it either lol!Ummm...
I am going to answer this question with another question (Plato-Fy). Are you requesting more ROMs for this phone?Dear Wizard ( If Any )
Can you please port any of LG devices kitkat rom which is similar to LG Volt. So that so many people can happily leave with the LG Volt.
Yes sir. I am bcuz of stock ROM has bug. If bypass activation the call log is not working. Do couple of reset then its start working, but after zero hour no update of call log and the call log will not be working as its own order.I am going to answer this question with another question (Plato-Fy). Are you requesting more ROMs for this phone?
There has been a few created... Look under root lg volt forum.Yes sir. I am bcuz of stock ROM has bug. If bypass activation the call log is not working. Do couple of reset then its start working, but after zero hour no update of call log and the call log will not be working as its own order.
Yes dear now I'm using the PAC rom from yesterday it's really nice. And same camera green tint issue. But overall nice.Hey brother try. Saber Pac Rom Port. Should not cause activation issues and has great features.
http://androidforums.com/threads/port-saber-pac-rom-4-4-4-lg-l90.991943/
