Root Need root help
I am having a problem rooting a Samsung Galaxy Ace 2.3.6 XXLD3. I have tried root.zip; superoneclick.zip; superoneclickv2.3.3.Shortfuse.zip and upd_1.zip. I always get "Application aborted." just after it starts to unpack the application. Has anyone got any ideas ?
Many thanks :-)
Many thanks :-)
Flash latest firmware for ace like XWKTM and try rooting
Have you tried AceGingerRoot.zip ?
I had same problem as you and that .zip is the only one that worked.
I Had Your Problem On My Gingerbread 2.3.6
and This Zip Successfully Rooted My Ace
Zippyshare.com - upd_1.zip
i Hope It works On your ace
Here is the leatest tutorial all options available to root your phone ;)
Download The Leatest Tutorial:
Universal Gingerbread Root & Unroot 2.3.3 -> 2.3.7+.pdf
