mondev
So I've had my Behold 2 for about 2 months now, and I've tried several different ROMs, but all of them have this same problem, apps always disappear after a reboot. Does anyone else have this problem?
Things such as google maps, navigation, places, springpad, dropbox, astrid tasks, handcent sms, even the android market sometimes is completely gone, not even in the apps list from settings. It only shows a white box with the green android, and when opened, it just says app not installed.
If I reboot/pull battery some of the apps mix n' match for which ones to appear and not. After one reboot, dropbox will be gone, while on another springpad will be gone but dropbox is back. So it's never the same.
I'm currently using BHMAN's latest take5 ROM, and I've tried 1.6 no twiz, microhaxo's OTA 1.6 tweaked as well as bearsfan's all having similar results.
Now when I first flashed a custom ROM, I used the unlockr's guide, and followed the rooting instructions there. Could it be that the rooted ROMs are interferring somehow with the already rooted phone?
Is it possible to unroot the phone and flash back to stock 1.5 or 1.6? Then I would try flashing to one the latest ROMs.
Any input would be greatly appreciated, thanks.
