Root need some advice
jonny wad
My admire took a bad fall last night. :mad: it still works but the screen looks like a spider web. The admire has been a great phone for me and im thinkin of buying another. Before i spend the money, i was hoping you all could give me yer thougts. Should i stay or try something new?
Motion, s3, connect (connect might get ics) but the motion comes with it... while the s3 is the superior to all of them and also comes with ics. ...its up to you if your into modifications and junk go for a device that has a strong community when it comes to development! (Think about it first)
ps: My my daughter sat on mines and cracked the screen ..... had to change it...
If you're willing to do the legwork, you can find R720 screen replacements for pretty cheap online. Just remember to use a heat gun or hair dryer before trying to pry off the screen and digitizer -- pulling while the adhesive is not warm will crack the screen and digitizer.
Thanks for all the advice. Im getting another admire today so ill be sticking around for awhile longer. I will most likely be trying the motion as soon as i can afford it, unless a S3 magically finds its way into my hand.
lol im earning free amazon gift cards to buy a Motion :D Im half way there buy its gonna take another month
the links are in my signature, but it also takes a good while to get points for these gift cards although they have a good variety such as Amazon, Paypal, Best Buy, Xbox Live membership. the first link i think is the slower one of the two seeing how its taken me 26 straight days to get 6986 points and i need 15000 for 3 $50 dollar gift cards on Amazon. The sites are legit though and well worth the time lmao. Of course you can also get lower denomination gift cards for much lower points like a a $5 gift card on the first site like is only 450 points which if done right takes about 2 or 3 days to get in my experience. in the second link to can get $5 for 500 points but there are more offers available on this site to do so its much faster and you can get $1 for 100 or $2 for 200. Either way check the sites out and use my links to join up, help an Admirer out lol
