My S2 is having a problem. Occasionally, while the screen is locked the processor will heat up. When I try to unlock it, it won't respond. The only way to recover is to remove the battery. When it comes back up I check CPU spy and it says my CPU was pegged at 1200 MHz. But I can't figure out a way to capture which process is the culprit. I tried watchdog but after a reboot it resets itself so any information is lost (Maybe I'm using it wrong?). It happened with stock GB, unrooted. Then I upgraded to ICS and factory reset hoping the problem would go away but it didn't. Now I'm running stock ICS, rooted, and still having the problem. The things I know it's NOT:
- SD card - it happens with our without the SD card installed
- GB or ICS dependent - it happens with both
- rooting problem - it happens rooted and unrooted
- a factory reset - I tried that
- a signal problem - it is not location dependent, and happens whether I'm on wifi or 4g
Can somebody help me figure this out? There are a few other threads around with similar problems, but none I've found have a solution.
