Need some help guys.
Mkulima
Am trying to move some apps to SD card but I get this notification "THE APP2SD FUNCTION IS NOT AVAILABLE ON YOUR PHONE!" And apos don't move. Please advise.
Thanks a lot for making me aware of this!
Is there anyway I can improve my phone's battery life? I mean more hours when am at work?
Battery life depends entirely on what you use your phone for and your usage patterns. My little sister inherited my Galaxy SL and she gets two days out of it. I was lucky to get 15hrs off it.
Battery saving tips would be to press back instead of home to properly close apps, don't use task killers, keep data off if not needed (or use a battery saver that toggles data on and off on a specific schedule).
my clone phone drains in about 2 hours. with the suggestion of funkylogic, i downloaded a cpu control app. i have it set to the minimum cpu when the screen is off. that has gotten me through the day.
there are some free ones, but i ended up getting setcpu which costs a few bucks but has a versatility the free ones do not.
