Help Need some help please
rippedcb
Hi all,
So yesterday one of my app crashed and decided to corrupt my sd card. The phone keeps on looping at the first screen and won't get past it. I can get into download mode (using vol down+home+power) but not into recovery. After doing some research i found out some peopel have been able to fix this by reflashing firmware. I have downloaded the firmware but have a few questions as i haven't flashed before using ODIN. Hopefully someone can answer these questions. I was running stock bell 2.2 (not 2.2.1)
1) Is there a tutorial on how to use ODIN?
2) what is a .pit file and where can i find that? I tried flashing the phone with firmware using ODIN but it said missing .pit file and flashing failed. Is it necessary to have a .pit file or am i doing something wrong?
3) i had OCLF running on this and i know we're supposed to disable all the lag fixes before flashing but i can't do that as the phone won't get past the first screen loop and i can't get into recovery. How do i go about doing this?
4) I'd eventually like to flash a custom ROM either darky's or team whiskey's.. would i need to worry about the network provider settings? ie) bell's network codes and stuff..
5) Is there a website that has a section with all the software for our phones?? Its pain in the arse trying to find software goign thru all the threads at xda
Thanks in advance,
CB
