Help need some help
Link: Custom recovery!
i tried using it and got an md5 error, currently downloading a terminal app and fixing with
Courtesy of Iandol off xda
Hi, I've made a few backups with this version of CWM, but when I try to recover one of them, it tells me there is a MD5 mismatch and refuses (normal or advanced restore).
Using adb shell, I see that all the md5 sums for the actually partition tars are correct, except the md5 of nandroid.md5 itself! So nandroid.md5 has a md5 of itself, which will always fail!!!
I think that is causing restore to fail - the data itself is OK, yet useless!!!! On backups that are recoverable, nandroid.md5 is not md5ed inside nandroid.md5 -- don't know why some backups fail to remove nandroid.md5 from the nandroid.md5 file...
Edit: for anyone having this problem, you must regenerate the nandroid.md5 file excluding the nandroid.md5 file itself. Using terminal, cd to your backup folder, delete nandroid.md5 and then:
Code:
md5sum [!n]* > nandroid.md5
This makes the backup directory restore properly. Not sure if this bug crept in in 5.0.2.8 or was present earlier...
Will post with updates as well if i get a working nandroid or not.
However on reg's side...if someone could get US a stock rom i dont have to do this crap and dig around for stuff to start working on modding the admire's files to ours.
