Root Need some help
jstoner
Trying to get my icons changed, and have no luck can anyone tell me how?
I used rom toolbox pro and im on version f detoxed this is what i get when i try
I believe standard icon replacers will not work because some of our icons are in a different file than usual, I could be wrong though.
You have to do it manually use ninjamorph to open systemui.apk then download what ever icon pack you want then go in mdpi folder and replace NOTICE that metro puts there name in the icon.
Ok so when i replaced the icon nothing happened. it just said it should be replaced and I haven't replaced it yet done at like 6 times plus rebooted and it still hasn't changed it any reason why
Also once you replace it you have to press the finish button in ninjamorph and choose the system ui file itself if it says creating package that is when it will automatically reboot or you can reboot and after phone starts up you should see your changed icon if not repeat all those steps again until it takes
I have used ninja morph alot and sometimes it doesn't take on the first time i had to do it again and it would change so thats it and good luck!!
