sammyz
LG Whiz Kid
I have 3 routers.
Primary router is Comcast's cable modem/wireless router/all-in-one. It is set up with DHCP.
Second router (D-Link DIR-615E3 running DD-WRT) is a repeater with a WAN port. It has only one port in the back when in this mode for internet use.
Third router is where I'm having a problem. It is a LinkSys WRT110 (no DD-WRT support). I want to use this third router as a physical LAN cable router by connecting it to the WAN port in the back of the repeater (second router). But the problem is that this third router doesn't like the other IP addresses (I'm guessing). Each time I connect it, it doesn't want to connect to the internet at all. It sometimes will for 10 seconds with LAN only but not WLAN. It is very confusing for me. I disabled DHCP because I assume the main router will assign DHCP, but again I'm guessing.
Here are the IPs of each router:
Primary: 192.168.1.254 -DHCP Enabled
Second (Repeater): 192.168.1.1
Third: I have changed it from 192.168.1.1 to 192.168.254.1 but it seems when I do that, I have to factory reset it to get it to connect via WLAN...LAN it works fine. But internet still isn't happening. I've tried other IP's as well, still no go. Don't know if it's second or third router's fault.
I only need the third router to connect multiple devices via LAN (two Vonage devices and a PC). I know you can connect vonage device to vonage device and then PC to last vonage device, but I would still like the router there for future use.
I do have the Wifi SSID as a different network for third router by the way since it can't be used as a repeater.
