Need some testers for ping tools
user51u
The program TestPing is designed for quick availability check ip address.
You can assign 20 addresses on the button, a quick check.
The test result will be displayed color, sound or voice.
You can also perform the scan using the standard ping.
The result of the check will be depending on the settings can be:
1. spoken voice (milliseconds)
2. will pronounce the phrase reserved for the range in which the result has got ping.
3. will synthesize the sound for a band who got the result of ping.
https://play.google.com/store/apps/details?id=user51.testping.proc&feature=search_result&hl=en
G0VRYabiu7de9WEDylW3mHokl9hsmO5BFyEUe2KblSQSjWpcMsI0cLvjhwJz3ym021Bi=h230
lq7R2bmGF16Cuy_uYITiXzv3KtwpF-Zmn_iRW-gPwmg98xPRnrPS5ZhxjTmJRrVJmQeY=h230
7dqh8K0lc0u7umol1zexWo3WraQHwuxKfM43PmlyxTGcyU9G8UWIIq6W8csug6Ym-w=h230
xOqxTT0y9pHthCcW1Gt97BecbNzetiGjJ7L6tYMryQ_HQLGbYx0VWxwNABwfo5WCq-A=h230
YiIu6NRmN4pgrAuAmMAqvSDjCzVSAycpuPXXOHh37iKQOtQsSGIB3bqgr5JxTn1-hxY=h230
ZtK-M_wM-UlbEnd9KRhRkZx1ElNus3H4YxgjmD2IhKTxGRcVyY0d-9nDlgqTLlQ74A=h230
