Dear All,
Good Day. Can any one give me the Stock build.prop file & /Carrier folder of activated volt so that i can use the stock rom easily from out side of usa.
The problem with that is security. If someone gives you their Volt's carrier folder from their activated device. It exposes their account.. No one will want to provide that.
You have to have the CORRECT carrier information for YOUR service provider in the area you live in or around. The stock rom will work everywhere, you just can't activate it if the provider isn't covering your area (roaming charges - $$$$).
